Page 1 of 3
Is RaceAnalyzer broken with V2 data?
Posted: Tue Jan 20, 2015 2:28 pm
by jakekooser
Trying to make sure I am capturing data, so I put my SD card in and tried to import the datalog, but RaceAnalyzer 1.1.15 isn't having it.
Am I missing something?
Posted: Tue Jan 20, 2015 2:53 pm
by jakekooser
nevermind, I just read that after I posted.
Note, Due to the significant changes in the firmware, the RaceCapture .rcap configuration files are not compatible with the new configuration file format
so how do we analyze the data now?
Posted: Wed Jan 21, 2015 12:39 am
by unbalancedengineering
I'm with Jake. Is the script to translate the data to GEMS format also broken then?
Jason
Posted: Wed Jan 21, 2015 1:17 pm
by gizmodo
The log files should work version to version. They have for me in the past anyway. .rcap is the configuration file for the hardware itself.
Posted: Wed Jan 21, 2015 1:47 pm
by jakekooser
"Should" being the key word here. That is why I attached the screenshot of RaceAnalyzer saying it didn't like the data shown in Notepad++ right below it, hoping someone could tell me if it looks like something is amiss.
Posted: Thu Jan 22, 2015 12:32 am
by toga94m
Looks like v2 firmware exports more subfields per data item..
ver 2.7.6 logfile partial header
"Interval"|"ms"|0|0|1,"Utc"|"ms"|0|0|1,"Battery"|"Volts"|0.0|10.0|1,"AccelX"|"G"|0.0|0.0|10,"AccelY"|"G"|0.0|0.0|10,
old version logfile partial header
"Battery"|"Volts"|1,"AccelX"|"G"|25,"AccelY"|"G"|25,"AccelZ"|"G"|25,
not just the additional columns INTERVAL and UTC (new timestamp related fields) but more pipe-delimited datapoints - looks like the format is now name|units|min|max|rate so there are more fields to parse, for either GEMS conversion or Race Analyzer. I'm also not sure how I configured my logging for a max battery voltage of 10V.. though I've been running it at home on USB power for a while now.
Here's a few lines from the github under \include\logger\loggerConfig.h
#define DEFAULT_ADC_BATTERY_CONFIG {"Battery", "Volts", 0, 20, SAMPLE_1Hz, 2, 0}
#define DEFAULT_ACCEL_X_CONFIG    {"AccelX",   "G", -3, 3, SAMPLE_25Hz, 2, 0}
#define DEFAULT_ACCEL_Y_CONFIG    {"AccelY",   "G", -3, 3, SAMPLE_25Hz, 2, 0}
#define DEFAULT_RPM_CHANNEL_CONFIG {"RPM", "", 0, 10000, SAMPLE_DISABLED, 0, 0}
and the typedef for channel configurations -
typedef struct _ChannelConfig{
	char label[DEFAULT_LABEL_LENGTH];
	char units[DEFAULT_UNITS_LENGTH];
	float min;
	float max;
	unsigned short sampleRate;
	unsigned char precision;
	unsigned char flags;
} ChannelConfig;
Also looks like it's been that way in src/logger/loggerApi.c since October 11, ver 2.1.0 - "added min/max/precision to streaming API metadata"
Posted: Thu Jan 22, 2015 1:31 am
Note, RaceAnalyzer not compatible with the V2 log format. The application has been sunset and analysis features are being moved to the new RaceCapture app.
Posted: Thu Jan 22, 2015 4:14 am
by toga94m
unbalancedengineering wrote:I'm with Jake. Is the script to translate the data to GEMS format also broken then?
I poked around some (hadn't tried GEMS or the script before) and got it doing something to V2 logfiles without complaining. Some data doesn't look right - my accelerations seem really low... but it'll create a new massaged CSV, which I can open in a spreadsheet or in DLog99, so it'll save as an STF. I have no idea what I'm doing in GEMS though.. but I can get some graphs of squiggly lines in DLog.
add to sub move_time_to_first_column
 		if ( $array[0][$i] =~ /\bUtc\b/ ) {  # make it read v2 firmware logfile
	            $timecolumn = $i;
and then...........
sub convert_time tries to break up the old HHMMSS.mmmuuu format using
Time::Piece->strptime to make HHMMSS into epoch seconds, then appending millisec
but since the new log format is already UTC millisec we just need to divide by 1000 and done.
 	my $newtime = $time / 1000;  # ver 2 firmware timestamp is UTC milliseconds already - tcm 21Jan15
	return $newtime;
Someone else is going to have to see if the numbers are reasonable in GEMS and DLOG99...
Posted: Thu Jan 22, 2015 3:57 pm
Hey Brent,
I was familiar with Raceranalyzer and was expecting to use it to look at the data from the Racecapture pro. Is the Racecapture app ready for analysis? Mine says "coming soon". If not, what are we supposed to use in the mean time to look at the data?
Jason
Posted: Sat Jan 24, 2015 10:51 pm
Brent?
I have data from last weekend I'd like to look at to make sure the sensors I installed are functioning correctly.
Jason
Posted: Sat Jan 24, 2015 11:00 pm
Hi Jason,
We are a couple of weeks away from getting basic analysis available in the RaceCapture app. What other customers typically do are these very popular things:
1) streaming data in real-time via http://www.race-capture.com, where they use the analysis tools on-line. This is the most popular use case.
2) Doing video overlays with RaceRender and similar programs (which is also a very popular use-case)
3) slice and dice their own data using visualization tools (excel, other analysis apps and tools)
The data visualization in RaceAnalyzer is significantly lacking in that it is not aware or laps or distance. We are adding the capabilities in the new analysis tools for the RaceCapture app to be aware of both laps and data over distance, important for race analysis.
We'll keep you updated as we go. Thanks!
Posted: Sun Jan 25, 2015 1:02 am
I assume option 1 requires a cell plan for the device?
Posted: Sun Jan 25, 2015 6:09 pm
There are two ways to stream real-time data: via the optional internal cellular telemetry module, or via a Bluetooth connected Android phone or an internet connected tablet.
setup instructions here:
http://autosportlabs.net/RaceCapturePro ... Quickstart
Posted: Mon Jun 15, 2015 12:27 am
by GTIspirit
brentp wrote:Hi Jason,
Bump because it has been a few weeks......
Streaming real time is not an option without a telemetry unit and only an iPhone.....
Might have to revert back to the last V1 firmware to get RaceAnalyzer working for data analysis.....
Posted: Tue Jun 16, 2015 8:41 pm
Can we roll back to V1 on the new hardware? I didn't think that was an option....
I'm about ready to ditch the whole thing and go another way.... Without a way to pull the data and do real analysis, what's the point....
