Tapping existing Tach line
Posted: Sat Jan 31, 2015 7:54 pm
by TheArchBish
I'm new to this so bear with me. I have an MSD 6AL Ignition Controller and it outputs a tach line - delivers 12V square wave. Can I tap directly in to this for RPM on RCP or do I need some sort of resistor to reduce voltage down to 5V.
Posted: Mon Feb 02, 2015 2:54 pm
by gizmodo
I have an MSD tach adapter that outputs the same signal, a 12 volt square wave. When I asked Brent he said it should be fine since the inputs are protected. I haven't been able to get a signal from it though. Brent did say he ordered a tach adapter to test with, but I haven't heard if he had any luck with it.
Posted: Mon Feb 02, 2015 2:59 pm
by TheArchBish
Thanks for the info. As its protected I think my best bet might be to take the Tach signal directly from the 12v square wave off the MSD ignition controller. It worked with my old ChaseCam logger. I was just worried about the 12v v 5v mismatch.
Posted: Mon Feb 09, 2015 5:21 pm
Hi TheArchBish -
Yes, we ordered the MSD tach adapter recently and we have it on our test bench to evaluate the signal. It wasn't clear to us if it supplies a clean 12v or 5v square wave, so that's why we were curious.
Do you have an MK1 or MK2 RCP? for MK1 the recent 2.7.7 firmware addresses a pretty big RPM bug that people were experiencing; so if you have an MK1 you definitely want to update.
Posted: Mon Feb 09, 2015 5:23 pm
by TheArchBish
Brent. Mine is a Mk2 with the latest firmware.
Posted: Mon Feb 09, 2015 5:33 pm
Go ahead and connect straight to the clean 12v MSD 6AL tach line let us know how it goes. Note, you may have to play with the "pulse per revolution" settings in the firmware to dial in the RPM calibration.
Posted: Sat May 07, 2016 10:59 pm
by Mattik
How did it turnout, does it work with tacho signal from Msd to RCP?
We currently instaling Rcp to Drag car trying to sort out how to get rpm signal to RCP.
Will it work with CoilX connected to the Coil as the MSd gives multiple sparks per ignition?
Posted: Sat May 07, 2016 11:53 pm
by TheArchBish
Yeah worked fine. Only issue I have experienced is if you shut off the engine it tends to "stick" at the last running RPM. However once the engine starts again it all works again.
Posted: Tue May 10, 2016 5:32 am
Thank for the update.
Please try updating to 2.9.0 firmware - we fixed the stuck RPM issue as well as introduced a noise filter to help eliminate RPM spikes.
Posted: Wed Jul 06, 2016 4:47 pm
by HollyJuster
Hi i am new user here and by profession i am a hardware design engineer. I think my best bet might be to take the Tach signal directly from the 12v square wave off the MSD ignition controller. It worked with my old ChaseCam logger. I was just worried about the 12v v 5v mismatch.Go ahead and connect straight to the clean 12v MSD 6AL tach line let us know how it goes. Note, you may have to play with the "pulse per revolution" settings in the firmware to dial in the RPM calibration.
turnkey pcb assembly
Posted: Thu Nov 30, 2017 1:54 am
by viya0414
Posted: Thu Nov 30, 2017 1:56 am
Note; the latest firmware release should handle the sticking RPM value if the wire is disconnected.
