Different versions of MJLJ
Posted: Fri Jun 17, 2005 9:59 am
by AL Mk1
I am looking into adding MJLJ to my current project.
I have been in touch with Bill Shurvington here in the UK who can supply the system though he gave me some prices based on the "TPS" (I assume - Throttle Position Sensor) version.
How many different versions are there and what are the main differences?
I am currently building a VW KR code 16v engine, which I am hoping to run on Honda CBR carburettors. I don't actually think I can attach a TPS to these carbs?
Reading through this site, I was planning on just hooking up the Manifold Vacuum (MAP) part. Is this right, or do I still need a TPS?
I'm a little confused!?!?!?
Cheers,
AL.
OK, I think I have worked out
Posted: Fri Jun 17, 2005 2:47 pm
by AL Mk1
OK, I think I have worked out that you can either hav an MAP (Manifold absolute Pressure?) sensor or a TPS - Is this right?
If so, which is the better setup?
Cheers,
AL
Visit My Homepage at:
http://freespace.virgin.net/al.macklen
Hello if you are using carbs
Posted: Fri Jun 17, 2005 4:49 pm
by Ivan
Hello if you are using carbs then my opinion is tps
The sensor can be placed on these carbs, I made a bracket to
fit twin dollerto's myselfe.
Ivan
If you can get a reliable MAP
Posted: Sat Jun 18, 2005 12:02 am
If you can get a reliable MAP reading, the MAP sensor is more accurate. It more accurately measures the engine load than measuring the throttle.
That said, I think you'll get satisfactory results from both.
The board is set up with a MAP sensor by default, but requires a mod to do TPS- it's a bit of a hack, but not too bad.
The next V3 board revision will have proper circuitry to support TPS and will be integrated into the main interface plug on the MJLJ.
Cheers guys...
I am actual
Posted: Mon Jun 20, 2005 7:43 am
by AL Mk1
Cheers guys...
I am actually going to try using Motorbike carbs. I have had a look at them and see no way of attaching a TPS at the moment.
I think I am going to have to strip down one of the spindle mechs to see if can be modified or a replacement made.
I would prefer to go with the MAP sensor, though on carbs, I believe it is difficult to get a good vacuum without pulses on low RPM?
Cheers,
AL
MAP
Posted: Mon Jun 20, 2005 9:36 am
by Josh_b
hi, i would say go for the map, i was worried about pulsing at low rpm as i have a fairly long duration cam and 2 twin 45 dellorto's i have 1 vacuum take-off from each carb and it works great!
Cool - I thought that the MAP
Posted: Mon Jun 20, 2005 2:09 pm
by AL Mk1
Cool - I thought that the MAP sensor would be the better option...
So would it be best to tap off one or two intake ports, or all four?
Cheers,
AL
the
Posted: Mon Jun 20, 2005 6:22 pm
by Josh_b
to get the smoothest signal tap 4, 1 or 2 would probably work fine though!
