RPM problems on all type of data loggers with new firmware
Posted: Mon Mar 30, 2015 10:07 am
Fist I like to relate to this video. And yes it works well with 50% PWM DC/AC this way but it’s not the reality as we use a hall sensor one pulse per crank rotation (not 50% PWM) so we get no RPM reading @ all while the engine runs. Only @ start-up we get some RPM spikes and it hold the last RPM reading as well even when no signal is fed into the data logger.
https://www.youtube.com/watch?v=12Z9JbnwTUs
We had the MK1 data logger working well on the RPM reading before we upgraded the new firmware and now have the same problems as with the MK2 types. Suggest to jump back on older type of soft/firmware as this was working well.
This is how the data logger reads RPM. On the left the RPM the ECU reads and on the right it should display the crank RPM from the data logger. Also fast medium or slow timer speed makes no sense as it changes the reading or freaks the reading out totally.
https://www.youtube.com/watch?v=50SeI3J ... e=youtu.be
