Bricked my RaceCapture pro 2
Posted: Sat Apr 04, 2015 4:29 pm
by Max
Hello,
i change something with the PWM output, now i can't connect to the RCP. Not with bluetooth and not with USB. Only Updating (Bootloader) is working. Is it possible to reset the internal configuration to default?
Please help.
Max
Posted: Sat Apr 04, 2015 4:53 pm
by toga94m
This is a non-official answer.
In Windows Device Manager, does it show up as a COM port when you plug it in by USB, before trying to use the RCP app? If so, you can probably talk to it by a terminal program (like putty or termite), and then send the command 'resetConfig' to put it back to factory. If that won't work, running the bootloader and reflashing firmware (even the same version, 2.7.9?) should get it going.
Posted: Sat Apr 04, 2015 5:57 pm
by Max
The problem is that the RCP connect -> disconnect in a loop. Without to have the RCP App open. So i can't use the terminal...
I tried to update the firmware again as written above. But doesn't take any effect. In the documentation is written that bugfixes do not reset the configuration. So i need something like 2.8.x.
Posted: Sun Apr 05, 2015 7:25 am
by Max
Is some one able to create firmware file which resets all settings to factory default?
(Wouldn't be that a nice button in den App)
Next week i have a trackday and i need this box! :/
Posted: Tue Apr 07, 2015 8:02 am
Hello,
Sorry you're having problems getting the firmware flashed. Try this:
Flash the attached 'recovery' firmware. re-start RCP.
Then, flash the latest firmware (currently 2.7.9) available in the downloads.
Finally, restore your configuration.
if you still have the problem after restoring your configuration, please email us the configuration file you are using and we will investigate.
thank you,
Posted: Tue Apr 07, 2015 9:14 am
by Max
Perfect.
I will try this tonight. If that is working i try to reproduce that and write it down what i did. Maybe it is interesting for you to avoid such error. It was pretty easy!
Posted: Wed Apr 08, 2015 9:16 am
by Max
So everything worked. Thank you very much.
My to do is to reproduce that. I will informe you if i have something new.
Posted: Tue Apr 28, 2015 10:18 pm
Glad things are working now. Sorry for the hassle!
