I'm trying to get my Mk1 RCPro hardware updated with the new RaceCapture app. But either the hardware of the app freezes about 2/3rd of the way through the config upload.
What's wrong with the .rcp config that's causing the hardware to freeze the the red LED to illuminate?
RaceCapture app freezes when uploading config
- first_initial.rcp.txt
- RaceCapture app config to reproduce last valid RaceAnalyzer config. (Delete the .txt filename, workaround because forum doesn't like .rcp format.)
- (17.06 KiB) Downloaded 940 times
- 20150531_Configuration.rcap.txt
- Last RaceAnalyzer config, trying to get this put into the V2 RaceCapture app. (Delete the .txt filename, workaround because forum doesn't like .rcap format.)
- (10.91 KiB) Downloaded 891 times
For comparison, this preliminary config worked, it successfully uploaded to the device, and downloaded from the device.
So why does this one work and the first_initial.rcp doesn't work?
- initial_functional.rcp.txt
- Preliminary config doesn't freeze when uploading to the device.
- (17.02 KiB) Downloaded 784 times
Not sure which particular configuration setting was causing the app to freeze. I went through the configuration item by item, writing to the RCPro after each change so I could narrow down which configuration caused the app to freeze. Except none of them did.
So it's like the freezing was caused by trying to write too many changes at once? Maybe it prefers incremental changes rather than a whole bunch at once
Only other thing I noticed was when trying to write from the script screen then it consistently froze. But when it was freezing the other night I wasn't on the script screen.
So in the end this config ended up working, and this config is nearly identical to the one I previously reported caused freezing.
- first_valid.rcp.txt
- First valid/functional config.
- (17.06 KiB) Downloaded 795 times
Sorry for the late reply! Is this still happening with the latest firmware (2.8.5) and the latest app? (1.3.13) ? you can download both from http://www.race-capture.com/software.
