CoilX and a 4l80e tranny
Posted: Sun Jun 28, 2015 5:56 pm
Hello from Netherland,
I have been fighting a problem for over 2 years until I found this great place.
So here is a short story, I have this truck with a electronic od transmission that was controlled trough the stock ecm that also controlledthe tbi injection.
I upgraded to a standalone injection system with aftermarket distributor, but the stock ecm needs a clean 5Volt Vref signal to know wat rpm the engine makes to get the lockup to work.
I then put a wire from the negative coil side to the 5Volt vref and that fried my ecm to the death.
I replaced the ecm and now manualy use the lockup with a switch.
So I ran into the CoilX that should do the trick to get me a clean signal, but I have questions to where to put the +5Volt wire, output wire and the negative that goes to the "raceCapturePro" that I obviously do not have.
Here is a wiring diagram of a stock Chevy tbi distributor where you can see the inputs of my ecm:
I hope some of you could help me out, I allready have ordered the CoilX that should do the trick.
Someone told me the B5 conection on the ECM Reference high should need a square 5volt signal, but he was not sure.
