TIM + Racetech Rev counter issue
Posted: Fri Sep 11, 2015 9:14 pm
Hi all,
My MJ v3.3.2 is working well on the sprint/hillclimb mini.
I bought a Racetech rev counter to replace my TIM cheapy rev counter (running with the zener diode circuit from the install guide) that was bouncing quite a bit.
I've never been able to get the Racetech working with either the direct tacho out from MJ pin 8, or the zener diode circuit, or an NPN Transistor/resistor circuit that someone suggested on a Licost forum..
Can anyone recommend a fix to get the Racetech working or (if all else fails) a rev counter that works directly from the MJ pin 8 tach output?
Many thanks
Many thanks
