analog channel 8-battery
Posted: Sun Jan 31, 2016 9:40 pm
by G111ORH
Hi there - this channel is showing 5volts as battery voltage....... what am I doing wrong?
Posted: Mon Feb 01, 2016 5:21 pm
by toga94m
I'd say you're operating from USB power instead of vehicle 12V power.. but when I do that, mine shows as about 4.2-4.3V and not the full 5.
Posted: Mon Feb 01, 2016 8:00 pm
by G111ORH
Its showing 5volts when on car battery power..... how do I get it to read real car volts?
Posted: Tue Feb 02, 2016 1:09 am
by toga94m
Does it show 5V thru the app, or will it log 5V for battery if you hit the button and run a short log? What hardware (MK1 or MK2) do you have? I haven't wired my MK1 to anything other than vehicle power thru a cigarette lighter cable - all the other connections are vacant.
Posted: Fri Feb 05, 2016 3:00 am
by zechdz
I have a feeling he's talking about the 5V reference output.
I thought for a while that was the channel-8 seeing that it is physically to the left of channel 7.
Posted: Sun Feb 21, 2016 8:45 pm
Are you reading this via USB connected app, or via bluetooth?
One thing to ensure is that 12v is actually present at the terminal block at RCP. If you're connected via USB you might be tricked into thinking it's powered up.
A simple test is to disconnect USB, then ensuring RCP is still powered up; then you can monitor battery voltage.
Finally, it's possible the battery voltage calibration might be off. If you're still seeing issues after the above steps, please attach your configuration here and we'll take a peek at it.
Keep us posted!
Posted: Mon Aug 15, 2016 7:46 pm
by G111ORH
sorted..... channel configuration set wrong.......
