MBE Canbus Setup
MBE Canbus Setup
Hi all,
I've been setting up CAN logging on my RCP mk2 for my MBE 975 and I'm getting good success.
One thing I've noticed is that when I turn on the ECU without interfacing with the ECU software, CAN messages are not transmitted from the ECU. After I interface with the ECU software CAN messages are transmitted and continue to be transmitted even when I disconnect the ECU software interface until I power down the ECU.
Do I need to send a message to the ECU from RCP to initialize transmission from the ECU. I guess this is what the ECU software interface is doing.
What are your thoughts?
I will submit a script and write up on interfacing with the MBE ECU when I have completed the debugging
regards,
FitDes
regards,
FitDes
Based on what Race Technology says, you need to activate the outbound information using the ECU software. https://www.race-technology.com/wiki/in ... lInterface
Further issues with number of channels
Some progress being made but have run into an issue where the Canbus results flicker/jbberish when I configure MBE to output more than in CANID of data. My AIM dash noes not have this issue. Data coming off the bus looks like this.
814.0, 3.0, 129.0, 129.0, 200.0, 200.0, 10.0, 0.0, 30.0,
814.0, 2.0, 40.0, 0.0, 20.0, 255.0, 61.0, 0.0, 0.0,
814.0, 1.0, 97.0, 136.0, 2.0, 34.0, 24.0, 179.0, 81.0,
Also I did a log when I connect the ecu interface. Log below.
213782785.0, 3.0, 4.0, 0.0, 13.0, 247.0, 191.0, 255.0, 254.0,
213778705.0, 16.0, 13.0, 228.0, 0.0, 13.0, 35.0, 57.0, 55.0,
213778705.0, 33.0, 53.0, 103.0, 99.0, 57.0, 57.0, 48.0, 0.0,
814.0, 1.0, 109.0, 0.0, 0.0, 42.0, 48.0, 150.0, 84.0,
814.0, 4.0, 110.0, 78.0, 176.0, 101.0, 110.0, 5.0, 0.0,
814.0, 3.0, 129.0, 129.0, 158.0, 158.0, 18.0, 0.0, 115.0,
814.0, 2.0, 40.0, 0.0, 20.0, 255.0, 156.0, 0.0, 0.0,
Think the secret to initializing Can broadcast by the MBE ecu for both Racecapture and my AIM dash are in getting Racecapture to broadcast the messages for ID213782785
- MBECan.JPG (50.31 KiB) Viewed 8251 times
MBE Canbus Gains and Offsets
After a bit of searching through the Microsoft Access based database for AIM Mxl software I believe I've managed to isolate the gains and offsets required to convert the Canbus stream into something useable
- MBE Gains.JPG (51.85 KiB) Viewed 8249 times
Is the raw stream on Canbus from MBE different?
The address ID does not increment but the first bit becomes the offset.
How can I script to ensure Racecapture can read this properly
Address ID is in RED
Offset is in Blue
Offset is in Blue
Mux Script
Tried the script below to try deal with the Multiplex problem but with no luck. Any help would be gratefully accepted!
--This example configured for MBE 992CAN mapping
--how frequently we poll for CAN messages
tickRate = 30
--the CAN baud rate
CAN_baud = 500000
--CAN channel to listen on. 0=first CAN channel, 1=second
CAN_chan = 0
--add your virtual channels here
--format addChannel(<name>, <sample rate>, <precision>, <min>, <max>, [units])
muxId = addChannel("Mux", 10, 0, -30, 130, "C")
coolantId = addChannel("tCoolant", 10, 0, -30, 130, "C")
rpmId = addChannel("RPM", 10, 0, 0, 20000)
rpm2Id = addChannel("RPM2", 10, 0, 0, 20000)
tpsvId = addChannel("vTPS", 10, 2, 0, 5)
tpsId = addChannel("rTPS", 10, 2, 0, 16, "#")
batId = addChannel("vBatt", 10, 1, 0, 20, "#")
airtId = addChannel("tAir", 10, 0, -30, 130,"C")
gearId = addChannel("Gear", 10, 0, 0, 6,"#")
oilpId = addChannel("pOil", 10, 1, -30, 130,"C")
oiltId = addChannel("tOil", 10, 0, 0, 8,"bar")
ignId = addChannel("iOut", 10, 1, -20, 60,"deg")
injId = addChannel("zInjection", 10, 0, 0, 720,"deg")
lamId = addChannel("lMeasured", 10, 3, 0, 2,"#")
manId = addChannel("pManifold", 10, 1, 0, 300,"kPaA")
lamsId = addChannel("lSetpoint", 10, 3, 0, 2,"#")
lauId = addChannel("Launch", 10, 3, 0, 2,"#")
--customize here for CAN channel mapping
--format is:
--[CAN Id] = function(data) map_chan(<chan_id>, <data>, <CAN offset>, <CAN length>, <multiplier>, <adder>, [filter])
CAN_map = {
[814] = function(data)
if map_chan(muxId, data, 0, 1, 1, 0) == 1 then
map_chan(coolantId, data, 1, 1, 0.62745, -30)
map_chan(rpmId, data, 2, 2, 1, 0)
map_chan(tpsvId, data, 4, 1, 0.019608, 0)
map_chan(tpsId, data, 5, 1 , 1, 1)
map_chan(batId, data, 6, 1, 0.078, 0)
map_chan(airtId, data, 7, 1, 0.62745, -30)
elseif map_chan(muxId, data, 0, 1, 1, 0) == 2 then
map_chan(oilpId, data, 2, 1, 1, 0)
map_chan(oiltId, data, 3, 1, 0.62745, -30)
map_chan(mapsId, data, 4, 1, 1, 0)
end
end
function onTick()
processCAN(CAN_chan)
end
--===========do not edit below===========
function processCAN(chan)
local msg = 0
repeat
local id, e, data = rxCAN(chan, 0)
if id ~= nil then
local map = CAN_map[id]
if map ~= nil then
map(data)
end
end
msg = msg + 1
until id == nil or msg > 100
end
--Map CAN channel, little endian format
function map_chan(cid, data, offset, len, mult, add, filter)
if offset + len > #data then return end
offset = offset + 1
local value = 0
local shift = 1
while len > 0 do
value = value + (data[offset] * shift)
shift = shift * 256
offset = offset + 1
len = len - 1
end
local cv = value * mult + add
if filter ~= nil then cv = filter(cv) end
setChannel(cid, cv)
end
initCAN(CAN_chan, CAN_baud)
setTickRate(tickRate)
tickRate = 30
--the CAN baud rate
CAN_baud = 500000
CAN_chan = 0
--format is:
CAN_map = {
end
end
function onTick()
end
local msg = 0
repeat
if id ~= nil then
if map ~= nil then
map(data)
end
end
msg = msg + 1
end
offset = offset + 1
local value = 0
local shift = 1
while len > 0 do
shift = shift * 256
offset = offset + 1
len = len - 1
end
setChannel(cid, cv)
end
Thought this might work. Still no luck. No idea now
processCAN(chan)
local msg = 0
repeat
if data[0] == 1 then
if id ~= nil then
local map = CAN_map1[id]
if map ~= nil then
map(data)
end
end
end
if data[0] == 2 then
if id ~= nil then
local map = CAN_map2[id]
if map ~= nil then
map(data)
end
end
end
msg = msg + 1
end
processCAN(chan)
local msg = 0
repeat
if id ~= nil then
if map ~= nil then
map(data)
end
end
end
if id ~= nil then
if map ~= nil then
map(data)
end
end
end
msg = msg + 1
end
Latest update on my MBE 992
I have been going through this for the last week and I think I'm getting close. I'm not sure if my car setup makes any difference, but the 992 ECU has a 998 ECU piggybacked for gearchange and wheelspeed, and I also have the 995 mini-dash that works off the CAN BUS.
The steps are similar to yours above:
1) Setup the MBE 992 Output for data collections with Easimap 6, using the documentation from AIM sports
2) Use the RCP Mk2 as a CAN Sniffer to see any CAN messages
3) With my setup, the 995 mini-dash uses the CAN BUS to cycle through 7 different screens: Gear, Oil Temp, Oil Press, Fuel Press, RPM, Water Temp, and Battery Voltage. When I run the CAN sniffer, I happen to also get 7 different CAN ID's. The values run from 0 to 66,600. At this point, I can't figure out which is which.
4) Tonight, I'll run my engine a while and go through a cycle while logging the data. Hopefully the data will make sense on which CAN ID equals which parameter I see on the dash. Then it's a matter of using the gain and offset to get something that makes sense.
2004 Radical SR3
