Extended PID setup
Posted: Wed Apr 13, 2016 8:13 pm
Is there a way to setup and view data through the OBDII port for extended PID's? This is on a 2015 Corvette Z06 but I believe it is the same for many GM vehicles. Trying to see oil temp, pressure and knock retard. Here's what I've found for addresses for the PID's, I'm just unsure as to how to implement this into a channel. It appears that I can already see any of them that start with "0000" but not the ones that start with "22".
Successfully Logged GM PIDs --> Parameters
00002F --> Fuel Level (From Engine ECU)(%)
00000F --> Intake Air Temperature(°F)
000046 --> Ambient air temp(°F)
221940 --> Transmission Fluid Temp (GM Method 1)(°F)
000005 --> Engine Coolant Temperature(°F)
221154 --> Oil Temperature (Engine)(°F)
221470 --> Oil Pressure (Engine)(psi)
000049 --> Accelerator PedalPosition D(%)
000011 --> Throttle Position(Manifold)(%)
00000C --> Engine RPM(rpm)
FF1001 --> Speed (GPS)(mph)
00000D --> Speed (OBD)(mph)
FF124D --> Air Fuel Ratio(Commanded)(:1)
00000E --> Timing Advance(°)
2211A6 --> Knock Retard(Deg.)
FF1269 --> Volumetric Efficiency (Calculated)(%)
00001F --> Run time since engine start(s)
000006 --> Fuel Trim Bank 1 Short Term(%)
000009 --> Fuel Trim Bank 2 Short Term(%)
000007 --> Fuel Trim Bank 1 Long Term(%)
000008 --> Fuel Trim Bank 2 Long Term(%)
FF1214 --> O2 Volts Bank 1 sensor 1(V)
FF1215 --> O2 Volts Bank 1 sensor 2(V)
FF1218 --> O2 Volts Bank 2 sensor 1(V)
FF1219 --> O2 Volts Bank 2 sensor 2(V)
00003C --> Catalyst Temperature (Bank 1 Sensor 1)(°F)
00003D --> Catalyst Temperature (Bank 2 Sensor 1)(°F)
[/QUOTE]
[/QUOTE]
