I have an application where I will be sending data to the serial port of a RaceCapture/Pro MK2 and I need a Windows application that will capture the data and save it to a file.
Has anyone done something like this?
Is there a terminal type application that would do this already?
Does anyone know how to do this type of programming? I would compensate you for your help, of course.
A quick outline of the application is as follows:
Open COM port
Prompt for a file name or it can be assigned based on date-time.
Open file for writing
Wait for data to come in
Read data and store it (10 Hz)
Check keyboard, if Function Key or Esc pressed stop process, finish storing data and close file
Start process again.
When done with all testing
Close COM port
Exit the application
I imagine a couple of dozen lines of code is all that might be needed.
Thanks in advance and feel free to contact me off-line.
Capturing data from Serial Port
Return to “RaceCapture App Operation and General Q&A”
Jump to
- Autosport Labs
- ↳ General Discussion
- ↳ News and Announcements
- ↳ New Project Suggestions
- CAN Devices
- ↳ ShiftX2
- ↳ AnalogX
- RaceCapture App
- ↳ RaceCapture App Operation and General Q&A
- ↳ RaceCapture App Bug Reporting / Feature Requests
- CAN bus and OBDII integration
- ↳ CAN mapping discussion
- ↳ OBDII PIDs discussion
- RaceCapture/Pro | RaceCapture/Apex | PodiumConnect
- ↳ RaceCapture/Pro introductions
- ↳ RaceCapture/Pro General Q&A
- ↳ Sensors
- ↳ Hardware and Installation
- ↳ Lua Scripting
- ↳ Telemetry
- ↳ Bug Reporting
- ↳ Feature Requests
- RaceCapture/Track
- ↳ RaceCapture/Track Introductions
- ↳ RaceCapture/Track Operation
- ↳ RaceCapture/Track Installation
- ↳ RaceCapture/Track Bug Reporting / Feature Requests
- Megajolt/E and Megajolt Lite Jr. (MJLJ)
- ↳ Ignition Map Library
- ↳ Powered by Megajolt Gallery
- ↳ Assembly
- ↳ Installation
- ↳ Operation
- ↳ Q&A
- ↳ Future Upgrades
- ↳ Bug Reporting
- ↳ Fixes/Patches/Updates
- ↳ Hard Rev Limiter
