Analog Input Errors on 3 of 7 channels
Posted: Fri Jun 17, 2016 8:47 pm
Hi all,
I'm setting up my RCP2 for the first time and and using some K-type thermocouples with the Thermocouple Amplifier - AD8495 from adafruit.com
The problem I have is that on channels 1-3, the dashboard software shows a value that is not the value that the input pin sees. It works properly if I connect the signal to any of channels 4-7.
It's not scaling, because I have set the inputs back to Voltage and am just looking at raw voltage. My Amp is putting out about 1.38V which is perfect for 70 degrees or so, but connected to channels 1-3, it seems to float around. If I actually hook a mulitmeter to the terminal block, it reads the correct voltage (1.38) no matter which pin its plugged into. But the channel displayed on Dashboard is not reading the same, It's generally about 0.4V off, but seems to float a bit.
Right now, it's running with nothing hooked to any input and the values for each of the analogs are as follows. (I'm powering it via USB right now, but it acts the same with 12V power)
Analog 1: 0.19V
Analog 2: 0.19V
Analog 3: 0.19V
Analog 4: 0.30V
Analog 5: 0.53V
Analog 6: 0.77V
Analog 7: 0.90V
With the header plugged back in and the K-type hooked to #6 it's as follows.
Analog 1: 0.03V
Analog 2: 0.03V
Analog 3: 0.03V
Analog 4: 0.14V
Analog 5: 0.53V
Analog 6: 1.37V (correct for Signal from K-Type)
Analog 7: 1.03V
The longer its powered up, the more the values drift up (except the one that has an actual input signal).
Any help is appreciated. My fear is that I have a defective unit.
Aaron
Analog 1: 0.19V
Analog 2: 0.19V
Analog 3: 0.19V
Analog 4: 0.30V
Analog 5: 0.53V
Analog 6: 0.77V
Analog 7: 0.90V
Analog 1: 0.03V
Analog 2: 0.03V
Analog 3: 0.03V
Analog 4: 0.14V
Analog 5: 0.53V
Analog 7: 1.03V
Aaron
