ElapsedTime No Longer Preset in .LOG
imstimpy
Post by imstimpy »
I'd been using 2.8.6 firmware for the past six months. In the logs, ElapsedTime is present. Using ElapsedTime, I can sort of gain a useful delta between laps. I finally ran a track day with 2.8.7 and ElapsedTime is not present in the logs.
Where did it go?
Jon
This can happen sometimes with the RCP configuration. You can reset the Elapsed Time by doing this:
* Read the configuration
* Go to configuration - toggle race timing and predictive timing off, and then turn both back on.
* Go to GPS and change sample rate from 10 to 1Hz, then back to 10Hz.
* Write the config back to the unit.
* Be sure to save your configuration
This will trigger an automatic sanitization of your config and you should see Elapsed Time now in your dashboard.
Let us know if you're still stuck,
imstimpy
Post by imstimpy »
That seems to have fixed it.
Great! We have it scheduled to be auto-sanitized on the firmware side so this won't happen in the future.
