Melted RJ45 Connector
Posted: Fri Jul 29, 2016 6:02 pm
Hello,
Has anyone else experienced a melted RJ45 connector on the expansion port? My installation does have a 12V power source wired into a cigarette lighter plug. I occasionally connect to the RaceCapture2 powered by USB only (ignition switch off, 12V jack has no power). I run three analog 0-5V pressure sensors, three resistive temp sensors (pulled up with 2.2K), and GPS antenna.
I often move the installation from car to car, but I usually don't usually unplug the expansion port connector. While installing to an engine dyno today, I was inspecting all of the connections. I haven't powered it up yet to see if everything is functional, but I suspect its been like this for a while and I've been using the RaceCapture without issue with a melted RJ45 connector.
Cheers,
Tyler
Cheers,
Tyler
