Pressure Sensor Problems
Posted: Tue Aug 30, 2016 2:03 am
by m3drvr
I purchased a 10 bar pressure sensor with my Racecapture Mk2. After the usual months of procrastination, I finally plumbed it in to measure oil pressure and connected it to analog channel 1. I configured it to read 0-150 psi and set up the voltage mapping. With the engine off, the display read 20 psi. Once it started, the display still read 20 psi. To check the cable, I unplugged it from the sensor and shorted the power and sensor leads. The display read 150 psi. When I shorted the sensor lead to ground it read 0 psi. As far as I can tell, it is wired and configured correctly. What else do you recommend I check?
Thanks, Bruce
Posted: Mon Sep 05, 2016 5:06 pm
by rdoherty
Hi Bruce, can you upload your configuration here or a screenshot of the configuration for the sensor? Thanks!
Posted: Wed Sep 07, 2016 1:47 am
by m3drvr
Attached is a screen shot.
Posted: Wed Sep 07, 2016 11:15 pm
by rdoherty
The configuration looks correct, I would log just the raw 0-5v values to see what RCP sees. My guess is the sensor is not sending the correct voltage.
