PLX devices gauges
Posted: Tue Aug 30, 2016 11:11 pm
I was wondering if anyone knows about using PLX gauges (specifically the DM-6) without their sensor modules. I currently have 2 of them and would like to have the RCP output directly to them. This would be especially helpful for when I do not want to have my tablet/phone connected to the rcp while i'm just driving around but still want to monitor my oil pressure and temperature.
they have obd2 support with a separate module and then you can add sensor modules (like wideband, oil temp, oil pressure, egt...) to compliment what is not covered by the oem ecu.
here is what the gauge looks like.
http://www.plxdevices.com/Wideband-O2-A ... 002368.htm
and here is a company called adaptronic that made a little converter board to display stuff directly from their ecu onto the dm6 gauge.
http://www.turbosource.com/Adaptronic-P ... -65120.htm
and their little discussion on how it works... (which i do not really understand... hah)
http://www.adaptronic.com.au/forum/inde ... pic=5414.0
I am currently using a vipec i44 (similar to the link g4+) and have it outputting CAN information to my RCP which i'm currently installing.
I also have two dm-6 PLX gauges with boost, oil temp, oil pressure, and egt sensor modules. I want to completely get rid of the PLX sensor modules and have the sensors go directly to the rcp and have the same info (and more) available for viewing on the dm-6 gauges. PLX won't really share the communication protocol they're using but it looks like the adaptronic folks have figured it out...
thoughts?
thoughts?
