Virtual Channel for Logging on / logging off
Posted: Sun Sep 04, 2016 6:11 pm
by FHB-PERFORMANCE
Hi guys,
I am trying to get a virtual channel that shows when I am logging or not. The reason is if I want to record a 1/4 mile for each run, I want to make sure on screen that I am recording or not. It is much easier then checking if the Logging LED is on or off once the RCP is on the car floor, in the back seat.
I created a script using "getButton()" but it just shows me when the Button is pressed and not if I am logging or not.
Is there any other command like "getLogging ()" that would show me when is logging or not?
My script is:
GravId = addChannel("Gravando",10,0,0,1,".rec")
function onTick()
local a3 = getButton()
setChannel(GravId, a3)
end
BTW: "Gravando" means logging in my language.
Posted: Mon Sep 05, 2016 5:13 pm
by rdoherty
Currently there is no way to get the logging status in Lua, but that is a good idea! I will file a ticket for it. https://github.com/autosportlabs/RaceCa ... issues/849
Posted: Wed Sep 14, 2016 6:02 pm
by FHB-PERFORMANCE
Hi Ryan,
Thanks for that! Actually it would be very handy if you have the file number showing on screen too.
Cheers
Posted: Fri Oct 14, 2016 6:33 am
Idea:
If you have the Lua script actually controlling the logging start/stop in an automatic way, then you will be able to track that state as well in the script, then set that to a virtual channel.
let us know how it goes!
Posted: Mon Oct 17, 2016 5:32 pm
by FHB-PERFORMANCE
Hi Brent,
Actually I am not using the Lua script to start logging start/stop. I need to start recording around 3s before my test. For example, I have start logging and run the 1/4mile launch test. I need to collect the response delay from the accelerator pedal. All the car manufactures have a target for how much acceleration I need to have after certain time that the accelerator pedal was pressed, like 0.3s.
So, it would be very handy to have the file number on screen.
Thanks again,
Posted: Mon Oct 17, 2016 5:48 pm
Hi, actually, you can read the logging status within Lua, sorry for the confusion.
here is the method:
https://wiki.autosportlabs.com/RaceCapt ... ging.28.29
