Events
msmkarthik
Events
Post by msmkarthik »
Hey,
We are Team Raftar IIT Madras. We have been using Race capture pro MK2. We have earlier used Telemetry for observing the data. Under Ad hoc events I can see my device's data. But when I create new event, I dont get data. It shows the following.
No data.
RaceCapture/Pro has not connected and sent data to RaceCapture/Live.
Verify your device id is correct and the cellular module is working.
So kindly help me in this process and explain me the funda behind the events.
Thank you
Karthik,
Raftar formula racing, IIT Madras.
After creating an event, you will need to assign your device to that event. Once that happens, you will see data for that event once the RCP successfully broadcasts data.
Hope that helps!
