Link G4 and RPC cable compatibility
Posted: Thu Mar 02, 2017 6:38 pm
by WhiteAfrikanz
Hey guys I am looking to purchase RCP for my RB25 S13 that I am running Link G4 on. The cable from the ECU has a connector I am not familar with but goes to a USB, I am wondering the best way to connect to RCP. I am thinking a USB to RJ45 adapter then a male/male rj45 cable into the RCP. If anyone else has connected to LINKG4 please chime in. Thanks!
Ive attached a picture of the tuning cable that attaches to the female pigtail that is attached to the ECU.
Posted: Thu Mar 02, 2017 6:47 pm
I don't know about that cable from Link, sorry. However, we do know the connection from the Link is via CAN bus; I would recommend checking their documentation where the CAN bus connections are and then you can connect those to the equivalent CAN High and CAN low of RaceCapture.
Relevant information / guides:
https://wiki.autosportlabs.com/Link_G4
https://wiki.autosportlabs.com/RCP_CAN
Posted: Fri Mar 03, 2017 12:54 am
by WhiteAfrikanz
Hey Brent,
Thank you for your Help!
So I got this pinout and I know which pins are CAN
I can get a connector that attaches to the ecu and has flying leads. Would I be best off using that and wiring it into an RJ45 pigtail with corresponding flying leads?
Posted: Fri Mar 03, 2017 12:56 am
by WhiteAfrikanz
This connector
Posted: Fri Mar 03, 2017 1:37 am
Great! Yes, I would use that cable and splice it with a standard RJ45 ethernet cable as we suggest in our wiki.
