Unable to Connect Cellular - one other thing for you to try
Posted: Thu Mar 30, 2017 1:02 pm
Howdy, Brent helped me debug an issue getting my MK3 connected via cellular and I wanted to post it on here for reference in case anyone experiences the same issue.
After installing my SIM card, setting up RaceCapture and powering up my unit via USB I would not connect and kept seeing the following message:
[cell] manufacturer is u-blox
[cell] Loading driver for UBlox Sara U280
[USB] Starting telem stream on USB
[gsm] Failed to read phone number
[sara_u280] Failed to read IMEI
[cell] Command failed. Response:
[cell] Command failed. Response: 3
After playing around a while I randomly unplugged the unit from my USB port and plugged it into a 12V source and the cell connected immediately.
The cell phone is designed to be powered via a USB port however there is mostly likely a problem with the USB port on my computer not supplying sufficient current.
I just thought I'd document this on the forum in case anyone else experiences the same issue. It was a problem on my end - not with the unit.
-dave
-dave
