MK2 with bluetooth and wifi
Posted: Wed May 31, 2017 11:34 pm
by MrBlahh
is there any way to use a mk2 with bluetooth and wifi? I Was not sure if they both use the same port on the mk2, preventing me from using both.
I need to use bluetooth for HLT but I would like to start using another device as a dashboard & podium too
Posted: Thu Jun 01, 2017 3:47 pm
by dewittpayne
No, you don't. Wi-Fi also works with HLT. The RaceCapture/Track only has Wi-Fi.
Posted: Thu Jun 01, 2017 6:40 pm
Yes indeed; for MK2 you can connect both BT and WiFi. BT plugs into the inner port (closer to the button), and WiFi plugs into the outer port.
For reference, MK3 and RaceCapture/Apex both have BT and WiFi on-board.
Posted: Mon Jul 10, 2017 3:19 pm
by MrBlahh
dewittpayne wrote:I need to use bluetooth for HLT
I do have to use bluetooth for HLT or it cannot control the gopro over wifi.
that said the gopro's are buggy and fail to record as often as they record.
Posted: Mon Jul 10, 2017 3:22 pm
by dewittpayne
My Hero3 has been quite reliable as long as the battery is charged. The later versions seem to have 'features' that make them less reliable or even incompatible.
Posted: Mon Jul 10, 2017 8:22 pm
by MrBlahh
I have a 3 and I never had trouble with it either
I'm hoping some of the competition gets support too like the yi cam
