Peak hold in gauge for min/max
TXBDan
Post by TXBDan »
Brent, you mentioned you're adding min/max values in the data analysis section soon. It'd also be cool if those values could be displayed numerically inside an analog gauge. For example my water temp gauge could show the peak value in a smallish numerical display inside the gauge for quick reference. Or the "analog" display where there's fine red needle that holds at the peak value.
Hi Dan, thanks for that. Got something very similar being tracked here: https://github.com/autosportlabs/RaceCa ... ssues/1380
