Connecting to Innovate LC2 wideband sensor
Posted: Sun Jul 30, 2017 3:59 am
by kiwiracer
Hi.. Im planning out some of the AnalogX stuff, and how we can loop in more sensors
Innovate LC2 wideband (default is as follows)..
Analog output one (yellow) is 0V = 7.35 AFR and 5V = 22.39 AFR.
In RaceCapture App, what's a good way to scale this configuration for this custom sensors ?
Ideally it would give me a value between 7.35-22.39.. if I set the scale in the configuration, will it then show me the actual AFR value in racecapture
thanks
Posted: Mon Jul 31, 2017 5:08 pm
Hi, Are you connecting the wide band directly to the RaceCapture/Pro inputs? If so, we have a guide here that talks generally about how to calibrate a sensor:
https://wiki.autosportlabs.com/RaceCapt ... ate_Sensor
Hope this helps!
Posted: Tue Aug 01, 2017 4:36 am
by kiwiracer
That's a really good doc..
But I have a Race Capture / Track, so I assume I need the AnalogX to feed the sensor data into the ECU, then tap into those values on the CAN Bus ?.. Is that how this works ?..
Posted: Tue Aug 01, 2017 5:30 am
Right - in the case with AnalogX - it would read the voltage from the wideband and then report that voltage by sending a message on the CAN bus.
If you can share the voltage scaling - e.g. 0v = X AFR and 5v = Y - then we can construct a mapping for that AFR value.
The value is mapped using our CAN mapping system, documented here:
https://wiki.autosportlabs.com/CAN_Bus_ ... AN_mapping
Posted: Tue Aug 01, 2017 5:35 am
by kiwiracer
Ok, cool.
How's AnalogX going to plug into the CAN bus.. I have a Ecotec with a LE5 - it uses a E67 ECU and RaceCapture/Track.
Is there a way to add the message to the CAN bus, with some pins' on the Controller.. I guess that's something I need to work out ?
thanks
Posted: Tue Aug 01, 2017 5:45 am
So, It would connect by attaching the two CAN wires (CAN high and CAN low) to the existing CAN bus - then it would broadcast data along side the other traffic on the same CAN bus.
You'd also want to disable CAN termination by breaking the CAN termination jumper on the unit as well, documented here:
https://wiki.autosportlabs.com/AnalogX
I think a diagram would certainly help, we'll work on getting that added.
Posted: Tue Aug 01, 2017 5:49 pm
by kiwiracer
got it!, that's why it's called a bus !!
yes, a diagram would be super helpful
Im excited to get AnalogX..
- Fuel level will be epic to see up in Podium (oh and on our dash)
- WideBand O2 is critical to monitor, my drivers never look at it
And I may wire up the brake light sensor, could be cool to look at with laptimes, and analysis on breaking / acceleration to help our guys improve.
Posted: Sun Sep 17, 2017 5:27 pm
All analogx orders have been shipped, you should get your soon!
