Racecapture App for Windows Crashing
Posted: Fri Oct 06, 2017 1:48 am
by jd318
Every time I open the racecapture app on my windows 7 computer and try to open the analyze section it crashes. I've tried restarting the computer, and even uninstalled and reinstalled but not change. Anyone else experiencing this? I'm installing the latest version off the website (1.11.0).
Posted: Tue Oct 10, 2017 5:24 pm
by wizrd54
I always have this issue on my computer when opening the analog section of the setup area. No idea why it is happening. It seems to only happen on my laptop. Might try uninstalling everything and reinstalling it to see if that fixes it.
Posted: Thu Oct 19, 2017 3:12 pm
Hi, We've been investigating this.
Can you report your Windows version and also the graphics driver and graphics driver version? That information is reported under Device Manager.
Thanks, this information will help us diagnose the issue.
Posted: Sat Feb 09, 2019 10:41 am
by smallspeed
Hi is there a fix for this?
I’m running the latest version of the app, windows 7, and have the same issue - everything works fine until I click into analyse or the analogue sensor set up screen..
I can not upgrade to windows 8.1 / 10 as I will loose other functionality on the laptop
I can do most of what I need on a tablet or touchscreen dashboard but not all drop down menus are available so need pc to complete
Posted: Sat Feb 09, 2019 4:56 pm
Sorry, we don't have any anticipated fix for this on Windows 7. While we continue to research it, the cause is currently outside the scope of our control, as it is a very low level problem (and not a bug in our code)
You may consider trying to dual boot Windows 10.
Also, which aspect of the tablet interface are you having a problem with? If it is around keyboard use, we've found that a bluetooth keyboard is very handy in certain cases. We like this one: https://www.amazon.com/gp/product/B005O ... UTF8&psc=1
Posted: Sat Feb 09, 2019 8:11 pm
by smallspeed
Drop down menus for things like setting the number of pulses per revolution for RPM. You click on them, they open, if the selection you want falls outside the visible area of the screen you can’t get to it on a raspberry pi touchscreen - it just selects whatever you touch; maybe it’s just me I don’t know. I managed to get it to work with a tablet via WiFi
It’s a shame analysis doesn’t work on the laptop - I have to take it to the track anyway. I can’t dual boot, for some reason that screws something in my win7 and stops some of the other software working which I have to have for other things. I tried this once before and i lost a week of my life fixing it again :D
I guess I’ll pull the sd card and analyse it in a different software when I’m at the track or something
Posted: Sun Feb 10, 2019 2:56 am
Thanks for the feedback. As before, it's not a bug in the RaceCapture code, but if we can figure out a work-around we'll be sure to implement it.
