Feature Requests: Sensor calibration and screen rotation
Posted: Wed Feb 28, 2018 6:53 pm
Hi there,
just came back from our first racing weekend, everything went great and other competitors were really impressed by the product.
3 things that I would like to request:
1)Kilometers per hour: I know this is in the road map, but this would be great.
2)Screen rotation, even if it is a setting. We have a USB charging port wired into the car, but the phones rotation means we cannot charge and race.
3)Sensor calibration. We have used the GPX pro system before, and calibrating sensors was a breeze. You were able to set a value (temp/pressure/etc) and bind it to the current voltage. I find the current calibration a bit complicated if you are using sensors with pull up resistors, having to measure the voltage and calibrate the dash. So the feature request is to have n option to calibrate a value on the current input voltage.
Regards
Gerdus
Regards
Gerdus
