Missing SD card or logging error notifications support?
Posted: Mon Apr 30, 2018 2:17 pm
Will the new (upcoming) alerts allow for an alert when there is no sd card?
I have a racecapture/pro mk2 in an open wheel formula car that isn't "water tight", even in the cockpit where the rcp is mounted. A friend I race with also has a similar setup.
I raced a week ago and it was raining and I put tape over the ports/openings on the rcp box to help prevent water from getting in it. When I pulled the tape off that was over the sd card, it came out with the tape. I was worried I wouldn't have any data logged, but luckily for me, I did. However, my friend didn't get any data logged probably because his sd card was loose from putting tape over it.
I have a lua script that starts logging when the car is moving and stops logging after the car has been stopped for more than 30 seconds (or something like that).
Is there a way for the script to detect if the log file is being written or how to handle errors if it tries to turn logging on but there is no sd card (or it is full or whatever reason)? Will the script be able to display an alert for problems like that?
