MAP take-off location
rmaddock
Post by rmaddock »
Hello...another question about Series LandRovers.
Correct me if my assumptions are wrong but...the MJLJ unit has the actual manifold pressure sensor built into it. All that is required from the engine is a vacuum tube from some suitable point.
The question is what this suitable point is? Can it be before the carb'? The Zenith carb' on my LandRover is connected to the air cleaner via (amongst vaious bits) a 90 degree metal tube which is secured to the top of the carb with rubber hose and jubilee clips. This metal elbow already has a short take off pipe which is currently crimped and sealed....I've no idea what it might be for. Can I just open this up and slip a pipe over it?
________________________________
http://otly.mysite.orange.co.uk/
It should be an "un-ported"
It should be an "un-ported" vacuum take-off location. Meaning, it should have constant access to the manifold vacuum source. Some ports open and close depending on the position of the throttle plate, etc.
If your car has vacuum-assisted brakes then that port would be best since it always sees manifold vacuum.
greypride
Post by greypride »
it needs to be on the engine side of the carb so that it can sense the pressure of the engine, where i think your talkinbg about is just on the air filter side
try and find somewhere on the inlet manifold to take it from, or drill and tap it and fit a take off pipe, on my mini ive used the take off that used to supply the vacuum advance
is that on the carb on the landrover? presumably it will be fine in this case too
rmaddock
Thanks Brent. I have both
Post by rmaddock »
Thanks Brent.
I have both vacuum assisted brakes (cutting edge on a series III) and a vacuum advance on the dizzy........now that you point them out and I think about it.
Would the brake vacuum be better then? It's certainly a much larger diameter pipe than the advance. I guess though that the advance pipe is, by its nature, providing exactly the information required too.
I am correct though in that no other electro mechanical sensor part is required?
