Hi Folks,
I've been trying to get the RaceCapture/Pro 2 that I bought in Dec 2016 installed and working.
I cannot get the GPS module to initialize. Today I set the unit up outside with a clear view of the sky, connected to external power (not USB) and let it run for 6 hours.
I do not get an initialization error in the GPS System Status Window. It says "Status Not Initialized".
When I check poll log on the Scripting Screen, I get the following over and over again:
GPS: provisioning attempt
GPS: probing baud rate: 921600
GPS: probing baud rate: 115200
GPS: probing baud rate: 9600
GPS: Error: could not detect GPS module on known baud rates
I've tried to different antennas with the same result.
Do I have a bad GPS Module?
GPS Won't Initialize
Sorry we missed this earlier.
So to confirm, you have a RaceCapture/Pro MK2 (red box, correct?)
Let's figure this out.
First, what exact firmware version does it say in the upper right corner of the screen?
It should start with "RaceCapture/Pro MK2 " and then show the version number.
Thanks, we'll watch for a reply.
