Fuel pump relay
Posted: Wed Oct 30, 2019 10:00 pm
by dan97019
I am running a megajolt/E with the edis 4 module and I was wondering if anyone has used a standard fuel pump relay that triggers off the tach. signal like this one ( https://www.revolutionelectronics.com/Fuel_Pump.html ) and had it work with the tach. signal pin 11 on the edis module.
I have tried using the user defined output 4 on the megajolt module to trigger a relay with no luck my understanding is that it should trigger to ground when active but I get nothing, I do however get some conductivity to ground when the unit is off but when its on I get nothing, the UDO lights in the configurator software do come on like they should. I would prefer to use the UDO's on the megajolt if someone can tell me what I am doing wrong it would have to be simple though because my electrical knowledge is limited.
Posted: Fri Dec 06, 2019 6:55 pm
You can do some simple testing with the engine running and configuring an output to activate an LED or relay.
The wiring is simple; we have it described here:
https://wiki.autosportlabs.com/MJLJ_V4_ ... hift_Light
Please let us know how it goes. Thanks!
