Cant get 5v @ PS1 test location...
rickster
Post by rickster »
I've double checked every joint, all locations except the PS1 location between the 2 middle pins tests out just fine...any advise?
Probing around I can get +5v on the 2nd and third pins out from the DB9 connector on the PS1 header...but not the middle 2? Is the refrence picture correct? I found it abit unclear..maybe highlight the pins to make it absolutely clear?
I added this picture to help clear things up...
<img src="http://rickster.rb-com.com/images/megajolt-1.jpg">
The pins marked in red are not getting +5v, the pins marked in blue are...
I'm also not using the MAP, but the TPS option instead if that makes a diffrence.
I belive that's a mistake in
I belive that's a mistake in the build documentation. Yes- I need to fix it!
rickster
Thanks for the quick
Post by rickster »
Thanks for the quick reply!
So it really is the pins marked in blue that should read +5v...
