Megasquirt 3 Pro CAN data preset issue
Posted: Tue Apr 13, 2021 7:00 pm
I was able to get the CAN data working between the MS and RaceCapture, but I noticed that the numbers coming in for the AFR are actually the AFR Target, not the AFR data from the Megasquirt. I noticed the numbers on the RaceCapture for AFR did not match the one shown on the gauge and then verified that the MS matched the gauge. I was able to change the AFR Target table and saw the RaceCapture numbers change to match what I input into the MS table.
The settings according to DIY Autotune are as follows:
11 bit broadcasting
ID 1514 with an offset of 1 for the measured AFR
ID 1514 with an offset of 0 for the target
I cannot confirm what the settings are in the RaceCapture unit until I get back to the racecar.
11 bit broadcasting
