RPM Input
Posted: Wed Jun 02, 2021 5:58 pm
Hi there, I have some problem reading RPM from the coil. I have the race capture pro MK3. I tried connecting directly from the ecu coil #1 signal to RPM 1 Input but no luck. It work fine on other device, I checked with an oscilloscope and I have clean square wave. Tried pretty much every combination of timer speed and pulse per revolution but no luck. Is there a maximum input voltage or something else?? I'm a bit confuse and out of idea to make this work. Any idea??
