Hi, I am getting close to hooking up the EDIS, took the connector part off and found the molex type pins all corroded. I was able to pop the back end (one with the wires) off but can't seam to figure out how to remove the pins. The one on the front that is red has two small holes in it but would not come out. Saw the topic on where to get new fittings but nothing about the pins. Are they available, also I probably have the same problem on the coil plug.
Ron Triano
EDIS 4 Connections
Any help?
Is this page any help?
http://www.bowler.fslife.co.uk/diy_dist ... ectors.htm
I've managed to get my plugs to bits and clean them okay following these directions.
Got it apart but want new pins
Thanks for the help to get this thing apart, Anybody have a part # for the pins? would like to put in new pins and not have to put a butt splice on the old wires.
Ron Triano
Ron Triano
