crank position sensors
Posted: Sun Jan 29, 2006 4:29 pm
by emu
Hiya,
Ive had my megajolt setup running on my 1600 crossflow, but Im concerned about the mounting of the crank sensor. both its security and the accuracy of its positioning.
Now I had a thought yesterday. Is there anyway that I could use the electronic bosch distributor from a later escort to provide the crank position signal. The dizzy bolts into the block without any problems. Its normally works by sensing when one of four 'triggers' passes a sensor. obviously id need to cut this down so that it only had two 'triggers' (one each for TDC on 1 and 4).
My concern centres around the fact that ordinarily the megajolt recognises the missing tooth and therefore missing signal on a 36 tooth timing ring where as this way it would only get a signal as it came up to TDC.
Is this possible or have I just confused the hell out of everyone??
Cheers
