megajolt/E USB drivers?
dan97230
Post by dan97230 »
What usb drivers do I need for the megajolt/E (USB version) so it will work on windows XP? In the description it says there are easy to install drivers for older versions of windows but I am not having any luck finding them.
Also is it normal for the power and RPM lights on the megajolt to come on when only hooked up to a USB port on the laptop and not through the ignition on the car? Not sure if my older megajolt did that and I just never noticed.
dan97230
Re: megajolt/E USB drivers?
Post by dan97230 »
Well in case someone else ends up having the same problem I emailed autosport and Brent got back to me with this link to the driver
https://learn.sparkfun.com/tutorials/ho ... indows-710
Installed it as instructed and it worked in both windows 10 and XP machines
