VW Mk7 Reverse Engineering
Posted: Sat Oct 16, 2021 11:54 pm
by MattyYagr
I'm new to CAN mapping and using a RaceCapture Track for my Mk7 VW Golf R. Currently trying to identify the TPS sensor figuring that should be an easy place to start. I'm logging through RealTerm, converting into an Excel spreadsheet with filters to see individual channels, but unable am unable to identify the channel for TPS from my data. With the key on and engine off I depressed the pedal to max and back to zero twice and thought I would see a pattern of bits from 0-255 corresponding to my inputs but nothing seems to correlate. What am I doing wrong?
Re: VW Mk7 Reverse Engineering
Posted: Sun Oct 17, 2021 11:00 pm
by MattyYagr
UPDATE:
I was able to identify a channel that corresponds with my pedal inputs although the bits range from 40-220 rather than 0-255. This gives a me a gauge reading on Dashboard of around 16-86%, could this be the correct channel and just need an adjustment to the formula? I also noticed that when I use the OBD channel for TPS the gauge is giving the same readings.
Posted: Tue Nov 02, 2021 4:15 pm
Brake or TPS? Sounds like in the other post you're figuring out the brake pedal.
If it's TPS, and you're convinced it's accurate and consistent, then you could apply a formula and call it a day.
