Shfit indicator question
Nmunn
Post by Nmunn »
New to RC and trying to recreate a setup with have using tunerstudio as a dash. In TS we have a label that is made visible at a configurable rpm, basically a big yellow square that says "SHFIT". Is there a way to do something similar in the racecapture dashboard guage setup?
Re: Shfit indicator question
Yes, you can create something somewhat close to that.
You can configure a gauge (like your RPM gauge) to change color upon a certain threshold. You do this by editing the rules for the channel associated with that gauge.
You can also make a popup alert using the same rules.
Rules are accessed by pressing the gear icon next to the channel name when configuring the gauge, or, you can access the global list of rules from the main dashboard menu: Gear button in upper right -> More Settings.
Hope this helps!
Nmunn
Post by Nmunn »
Thanks @Brent. Will use whats available for now - Shift X will help.
