ODB replacement cable
Posted: Fri Feb 11, 2022 4:40 pm
by mtwlawson
I recently bought a replacement cable for my race capture. The original had a broken catch on the RJ45 plug that was causing data loss.
When I installed the new cable the RC unit would not power up. I have discovered that ground the old cable was wired to pin 4 (chassis) on the ODB plug, but the new one is wired to pin 5 signal ground.
Is this a fault in the new cable or a design change? How should I proceed?
Re: ODB replacement cable
Posted: Sat Feb 12, 2022 1:30 am
Can you clarify if your old cable still powers the RaceCapture system?
Where did you purchase the new OBDII cable?
Posted: Sat Feb 12, 2022 6:49 pm
by mtwlawson
Yes the old cable still works. I used a short RJ45 extension and taped it to the old cable to overcome to broken catch. I now have a working, if inelegant system.
The system and cable were both purchased from Petrel Solostorm.
Posted: Tue Feb 15, 2022 5:22 pm
by mtwlawson
BUMP.
Is there anyone who does customer service?
Posted: Wed Feb 16, 2022 6:46 am
It's great you found a workaround in the meantime.
We haven't yet seen an issue with these OBDII cables before not providing power to the device. So, it is a first for us seeing this.
Normally pin 4 and 5 are populated in vehicle OBDII ports and they both connect to ground - for low current applications they are typically considered interchangeable.
Can you peek into the port and let us know if there is a metal contact in both pins 4 and 5? What year/make/model is the vehicle?
We can check some of our existing cables to see if there are any variances.
Posted: Thu Feb 17, 2022 4:51 am
by mtwlawson
2014 Scion FRS
I will check the port tomorrow;
Posted: Thu Feb 17, 2022 5:11 pm
by mtwlawson
- Seems to have both connected
- IMG_20220217_115804960.jpg (216.89 KiB) Viewed 16931 times
Posted: Thu Feb 17, 2022 8:40 pm
by mtwlawson
I would have thought that for this application you would want to use signal ground. While they are at the same nominal potential signal ground should provide a less noisy signal for data. My car may be deficient in not providing a signal ground, but I don't understand why you would use chassis ground when I bought the unit and changed to signal ground without warning and perhaps even giving users the option of using pin 4 is pin 5 id not connected,
Posted: Sat Feb 19, 2022 12:46 am
Hi, we'll check our existing stock to see how our current cables are wired.
Posted: Tue Mar 01, 2022 4:57 pm
by mtwlawson
I need to know if ALL new cables are using Sig Gnd, if so are there is there a good reasons for the change from the original cable. If there was not an engineering reason for the change I will put a new RJ45 on the old cable and return the new cable. If there was a good reason for the change I will have to invest the time needed to find a Sig Gnd on the car and connect it to the ODB.
Posted: Fri Mar 11, 2022 10:56 pm
We checked our current cables and they do power up the unit on a standard OBDII port, tested on a Ford vehicle.
It's up to you if you want to return it, or put a pin in the OBDII connector of your car. Please work with your dealer on that.
Thanks for your patience with this unusual issue!
