output for cruise control
General discussion on Autosport Labs, the mission, website, content, etc.
BlackwoodLabs
Post by BlackwoodLabs »
I'm using a Ford cruise control which uses a 5v input for speed information with a pulse rate around 100hz for cruising speed. So tach data would need to be divided by about 20 to work. I don't see a problem with using a 12v signal instead of 5v.
Is there a way to set up this output from the Megajolt/E? There is no VSS.
Jim
BlackwoodLabs
Re: output for cruise control
I've been trying to work through the math on this with limited success and I think it looks like I need about a 4:1 multiplier so maybe a driveshaft mounted Vss could work with 4 magnets but it'd be cleaner if I could use an output from the MJ.
Specs I have say the input is 25hz @ 10mph + 20hz for each additional 10mph. So at 25mph it would be 65hz and at 75mph it would be 155hz. At 75mph the engine is turning lass than 2000rpm. 155 X 60 + 9300 pulses per min divided by 2000rpm gives 4.65 pulses needed per engine revolution but 4 should do it.
A tachometer output that is based on spark (tachometer output) is essentially double the ideal rate. It might work, I don't know what the upper limit is for these things.
2000 rpm x 8 = 16000 pulses where 9300 is ideal. In this case the number of pulses needs to be divided by 2.
So is there a way to do this?
THX,
Jim
BlackwoodLabs
AHA! One revolution is four ignition events, so it DOES run at tach speed. All I need is an additional tach output. Surely that is possible. The question is, how?
I just checked and the tach output from MJ is already connected to the VSS input on the cruise control. I may just have to make sure the configuration is correct. Has anybody done this?
BlackwoodLabs
Funny how it won't work unless the cable is hooked to the carb :shock:
Thanks for your help guys! :mrgreen:
Jim
Glad you figured it out!
