Wide band lambda on serial comms
RLittle
Post by RLittle »
Hi all , fairly new to this forum , installed a megajolt in my Ford GT40 recreation a few years ago but then life put things on hold due to starting a family etc. 3 boys now and starting to get time back in the garage .
Anyway. Have a Ford 302 V8 running on the megajolt but a the point now where I will be starting to look at setting carb jets etc and having installed a wideband Lambda I’m looking to see if there is any way to bring the lambda reading into the Megajolt software.
I currently have the lambda signal into my laptop through serial comms ( hyperterminal) and it displays the AFR ( or Lambda ) but would like to be able to see this on the same trend /graph as the RPM and MAP .
Has anyone down this before.? Or know if it is possible?
It would just be nice for tun8ng purposes to see on the same time base
RLittle
Re: Wide band lambda on serial comms
Post by RLittle »
Think I may have just answered my own question . Just realised the megajolt has a 0-5 v aux input. I can output the wide and lambda in a 0-5v analogue output and connect into megajolts therefore ultimately a better solution rather than trying to timesync serial data. Looks like just a track to be cut on the megajolt R6 circuit to enable the 0-5v scale.
Has anyone done this successfully?
