about the megajolt V4 and throttle position sensor Wiring
SEB79
Post by SEB79 »
about the megajolt V4 and throttle position sensor wiring, i 'm asking a question. I use to work with this :
http://www.autosportlabs.net/MJLJ_V4_ve ... _operation
but about the ground for the TPS, can you need to use a real ground on the car or it is better to use the ground on the molex connector (same for module and megajolt box v4).
Thanks for your answer.
Most definitely use the ground on the MJLJ- this will give you the most accurate signal.
Moreover, it's good to use a "star grounding" technique where the EDIS, MJLJ and sensors are grounded together at a common point.
SEB79
Post by SEB79 »
ok thanks
