Does this make sense?
Thanks.
EDIS6 Coil Firing Order
Interesting result.
When I hooked the coil up today with 12v and a spark plug I discovered my coil pin was a different.
I've updated my graphic to show the new lay out, the pins are 1=A, 2=B, 3=C...
Question, for the EDIS to coil wiring. It shows ABC from the EDIS to pin 123 on the coil, am I too assume the EDIS fires the coils in an order of ACB?
http://www.autosportlabs.net/MJLJ_V3_ve ... stallation 6 cyl model
Thanks.
Thanks.
