'78 Triumph Spitfire
starman
Post by starman »
Just got this working. Excellent system. Easy to set up, install and manipulate. Had no idea I was leaving so much performance on the table with the stock distributor, especially with an engine that is a significant departure from stock. Here are the particulars on this engine in my '78 Triumph Spitfire 1500:
1514 cc displacement (0.020” overbore), 9.6:1 compression, balanced
“big valve” head (p/n 218139) w/ modified combustion chambers, ported and shaved
bronze valve guides, 3-angle valve grind
1.5:1 Harland Sharp roller rockers on Tuftrided rocker shaft, stock push rods
“B” grind cam (280° duration, 0.409” valve lift) and V.549 dual valve springs
dual-row TR-6 timing chain and cam gears
twin SU HS4 carburetors and 4-2-1 header exhaust
Here's a photo of the car (more photos to follow of the installation):
starman
Post by starman »
some photos of the installation
13_complete assy.jpg (49.19 KiB) Viewed 33597 times
11_mounted+wired boxes.jpg (36.73 KiB) Viewed 33600 times
2_pulley and vr sensor.jpg (34.28 KiB) Viewed 33601 times
dr.occa
Post by dr.occa »
well executed!
love the su carbs.
AUTOSPORTLABS
NonStop Tuning
www.86garage.com
"Poverty is not a virtue."
starman
Post by starman »
Thanks dr.occa!
I'm including some more photos of my installation.
This photo illustrates the adjustability of the VR sensor in 3 important degrees of freedom: sensor to teeth gap, sensor centering and sensor angle relative to TDC.
starman
Post by starman »
mounted VR sensor
close-up of VR sensor mounted on its bracket, which is mounted to the front engine plate
starman
Post by starman »
EDIS and Megajolt box location
The EDIS and Megajolt boxes are mounted high in the left side footwell, on the inside surface of the firewall and the underside of the master cylinder mounting deck.
starman
Post by starman »
Megajolt and EDIS
Megajolt and EDIS, mounted and wired-up
starman
Post by starman »
I fabricated an interface mounting plate to allow mounting of the coil pack at the same location as the original coil using the original holes for the coil mount. The plate has 4 threaded holes to accept #10-24 machine screws for holding down the coil pack, and is attached to the car with two flat-head machine screws that go through the holes in the deck for the old coil mount, which also secure the bracket holding the heater control valve.
coil pack interface plate
starman
Post by starman »
Coil pack, mounted and wired-up.
coil pack
coil pack
starman
Post by starman »
The old distributor pedestal is retained to properly constrain the camshaft-driven oil pump drive gear. The distributor shaft hole is plugged with a rubber expandable freeze plug.
distributor close-out
starman
Post by starman »
The complete, operational Megajolt Lite Jr.-equipped engine in my 1978 Triumph Spitfire 1500.
complete configuration
alexander
Post by alexander »
starman, i know that gratuitous gushing can sound a bit corny, but that is exceptionally neat and precise work you have been doing there. the whole thing looks fantastic.
alexander.
alexander
Post by alexander »
alexander.
redkcspit
Post by redkcspit »
Starman,
Nice job on the installation. One thing I found after installing in my '77 spitfire, was that my tach was not correct so I made a LED tach and placed it in the ash tray (see photo). It runs off the six outputs. I like it there because I can flip the cover down when I don't want to see it.
