C20xe dispack
crd86
C20xe dispack
Post by crd86 »
Will the c20xe dispack work with megajolt the same as the ford one or would i be better with the for one? Thanks
Providing the basic design is the same, specifically the wiring for the coil pack primaries, it should be compatible with the EDIS module.
Can you post a picture of it?
crd86
Post by crd86 »
Yeh sure
That looks promising.
Double check which terminals represent common/coil 1/coil 2, and map that to the standard EDIS wiring diagram. If they check out you should be good to go!
