EDIS fitting to megajolt case
Is there any good reason not to attach the EDIS unit directly to the top of the Megajolt case. More specifically i want to attach the EDIS to an aluminium plate that would also hold my fuse block and ignition switched power relay, but attach this to the case with 3 short metal standoffs. I am a bit pushed for space (Caterham crossflow) and it would also give short wire runs, which would also be useful .
In the lab or in the car
It's a v3 tps controller.
It works from a space point of view, but wasn't sure about how much heat the EDIS generates, and whether the megajolt could cope, hence a sheet of alloyand stand-offs to give some heat sink capacity. Also does the case of the EDIS need to be grounded?
Thanks for the speedy response Brent
