Use EDIS without MJLJ - Fixed timing for aircraft 28*
Can I use the EDIS-4 setup without the MJLJ (aircooled vw engine for an experimental airplane) and run the timing at 28* fixed?
I would like to install the coil pack, trigger wheel, sensor and module but not the MJLJ box. Similar VW conversion aircraft engines run fixed timing of 28* all the time. I don't need TPS sensors or MAP sensors or advance curves as the engine will be operating from 2800-3200 rpm all the time.
Can I run the EDIS in limp mode and mount the sensor to give me 28* fixed? If limp mode gives me 10* how do I get 28*?
I believe the manufacture uses a simple Harley alternator, which is a fixed stator and a rotating drum-like thing with magnets inside. It's 20 amps total power, but I need the ignition to be around 8 amps max so I can run a radio, gagues, etc... I wanted to run dual EDIS-4 modules, dual sensors, and dual coils for redundancy. So I'm looking for 4 amps max for each coil. Engine RPM will be between 2800 & 3200 cruising and 3300-3400 takeoff.
Mark, have you heard of this?
http://www.aeroconversions.com/
They use dual redundant electronic ignition to run their twin-plug motor. I don't think they sell the ignition separately, though. Are you building your own engine? I have a little interest in type1 VW, one powers my 550 Spyder replica.
If my engine has more that 15 degrees advance, it kicks back and won't want to start. Admittedly, it has almost 10:1 compression and lots of valve overlap! I didn'y know you could start an engine with 28 degrees of advance.
