VR sensor dimensions
markhuebbe
Post by markhuebbe »
I want to make some custom CNC brackets to hold the sensors, but both of the ones I bought online are different sizes. The spacing of the two mounting holes is a little bit different.
FDEE-6C315-A2B
F3DE-6C315-AB
Those are the two model #s of the sensors.
Do anyone know which model is more popular? Does anyone know which cars go with which model?
I want to have some brackets made up and I want to make sure they will fit the most common sized sensor.
Post by NITROPIXIE »
Do you have any ics of the different type sensors to make things a lil clearer, as i think i have an idea what your talking about but not 100% sure.
markhuebbe
The dimension between the two bolt holes is slightly wider for one sensor. And the sensor is a bit fatter.
http://www.e-webcatalog.com/wells/PartF ... anuf_No=PA
Wells:
Manufacturer No: F3DE-6C315-AB
Part Number: SU4101
That is the fatter version.
I'm just going to exchange the smaller one from the company I bought it from.
I have absolutely no idea which is more common i'm afraid. The vr sensors on most fords over here are pretty similar to each other from what i have come across and the bolt hole is 90 degs from the one shown is and are alot longer in the shaft.
Sorry i can't be of help
