rev counter
bonkeye
rev counter
Post by bonkeye »
how do i convert the signalfrom the MJ to work with the factory rev counter in my car
thanks
Post by NITROPIXIE »
what car?? is it a saxo by any chance???
bonkeye
Post by bonkeye »
AX GTi mate
but it has a saxo VTS engine
bonkeye
Post by bonkeye »
anyone have an idea on this?
The V4 controller outputs a 12V square wave for the tach signal. This works with many tachometers. There are other techniques for driving your tachometer, in case this signal is not compatible, see here:
http://www.autosportlabs.net/MJLJ_V4_ve ... achometers
adsport69
Not sure if this helps but.........
Post by adsport69 »
If your AX GTI is anything like my 205, bearing in mind Citroen and Peugeot share technology, you might have to modify your tacho to accept the 12v pulse from the Megajolt.
This has been mentioned in another post (I am cheap and cheerful), but I removed the first two components in my tacho a resistor and a capacitor i think, and bypassed them, done this on three 205 gti tachos and they all work with the Megajolt 12v pulse. I decided to take a photo of the one I did this week and tested - worked fine.
I suggest you get a set of spare ax gti clocks and have a go at modding them, if you have MJ installed on your car you could try the VRSSIM to test it all - I always use it for testing Megajolt Installs.
Too many 205 GTI's
Turbo Techics, MI16
205 S16 Turbo Brewing
^^^ Thank you for the insight! :)
bonkeye
Post by bonkeye »
havent bought the MJ yet as i ordering it at the end of the month just thought id get as much info as posible
i'll have a look on the internet & see what signal they take
parky1972
Post by parky1972 »
I don't suspose anyone has any information on getting a rev counter working on a Mk2 Fiesta?
My gauge used to work on the old CVH I had in.
I've been told that the Megajolt feed doesn't work on these, so I got the Zeners and tried it that way. This works very intermittintly.
Now either, my gauge is fried, my wiring is bad or it just doesn't work with the Fiesta gauge.
Anyone got any advice?
Jason.
Other options are:
to try pin 11 on the EDIS module, this is the Clear Tacho Out (CTO) pin. I think you only get these on EDIS 4's.
test the diodes are connected up correctly.
Did you use 3 or 2 diodes?? If 3 you could omit the third one and see if this helps.
If all else fails then you may need to mod the tacho itself. If you can get a pick up of the circuit board on the back i may be able to work out the circuit.
