Since the Haltech uses the Coil signal to fire the Injectors... is it only to use tach output from MEgajolt to hook them together??
Hooking up Megajolt to Haltech or Electromotive EFI
I would think it should work.
I would think it should work. You have 4 different ways of hooking up a tach signal. MJLJ output, EDIS output, David Withers diode circuit or Josh B's new tach circuit. I can't beleive one of these would not work.
Todd
Todd
Thx! Yes it sounds promising
Thx!
Yes it sounds promising.
but anyone actually done this?
